I'm looking to replace the batteries in a couple of my old wireless headsets, including a Corsair HS70 Pro and a Sennheiser Momentum 2.0 Wireless.
I've managed to find a matching model for the Corsair at Communica (https://www.communica.co.za/products/li-poly-battery-3-7v-1100mah?variant=17184747225161)
However, the Sennheiser battery is pretty custom and a lot smaller (looks like it is approximately 40mm x 25mm). There is this battery from Micro Robotics that matches those dimensions pretty well (https://www.robotics.org.za/802540?search=800mah). However, this is only a 2 wire battery and the original Sennheiser battery has 3 wires. I believe the 3rd wire is for connecting to a thermistor to monitor battery temperatures.
Would it be ok to replace it with the 2 wire battery? If not, does anyone know where I can get a 3 wire battery matching those dimensions?
