Wireless ISP internet problem
ViciousClone
Western Cape
i dont know if im in the right place to post this,but hey here we go :)
oky so i have a 6mb wireless capped account with an Wireless broadband internet SP
browsing,youtube and emails,even downloads seem fine,no speed problems!
though when i want to play Battlefield3 i get kicked saying ,No packet flow.
so i did a speed test and ping test,speed test was fine,ping test reported packet loss up to 100% ,sometimes it goes through with no problems,but on the 3rd try it reports packet loss 100% again?
i cant join certain Teamspeak channels because of this as well :/ ..Does anyone know why?or is it a setting on the router i need to change or has anyone experienced such problems as well.
Sounds like a routing issue on the ISP side. Had the same'ish problem with mine. Turns out they had multiple fibre links & when load balancing was run on the lines it bombed out the session based traffic.
P00HB33R is on the right track here.
Also got a WISP and had the same problem basically.
My problem was realted to Punkbuster and BF3.
Long story short, they had multiple lines to load balance thus you are on different ip's at diffrent times and that causes the problem.
Solution = Static IP, got mine for +-R60p/m from the WISP.
mine is punkbuster related,Kicked:reason,no packet flow
Like Sli-man said, get a static ip from the isp and see if that fixes your problem.
