Wireless issue
Yuppie
Since I've converted to Linux, I've been having issues with my wireless. It disconnects as soon as the going gets tough. When I download multiple updates or a big file or so, then it disconnects and won't connect again.
Can someone please shed some light?
What linux distro & verion? what wireless adapter? Google also helps (once you know the answer to the 2 questions).
And it would also help to search through your networking logs in /var/log/ to see if there is something mentioned.
Oh my word. I feel like a brick! I left out the most important parts! Most recent ubuntu (think it's 10.10 now) and a cheap card, canyon something. @ Myworld, I checked the logs, must I be looking for something specific?
Oh and extra info, after it disconnects I have to restart the pc in order for it to work again.
The Canyon cards use the Realtek chipset, let me see if there is an error reported on the Ubuntu site.
Just to be 100% sure, give me the output of sudo lsusb .
If you look through your logs you will be looking for anything with "error" or "warning".
Also take a look at your dmesg, type dmesg in console.
EDIT:
It seems that the only quick fix I could find is to use ndiswrapper, which is not ideal at all but if you are in a pinch then it should work okay.
Read more here:
http://ubuntuforums.org/showthread.php?t=297092
Read the last couple of pages (the more recent ones) as well to see if there is a more 2010 fix.
EDIT:
Read more here:
Thank you. I'll check the forum. Meanwhile I installed the ndiswrapper. *fingers crossed*
Ndiswrapper did the trick. I now have signal strength almost 5 times greater, higher transfer speeds, no disconnects. Thanks for this!
:D
Your welcome.
I'm just a bit bothered that the native drivers did not work, my wifes PC uses a Canyon USB dongle and it works out of the box with the firmware supplied in the Ubuntu kernel, I have never had issues with it.
Oh well, as long as it works well.
Wireless network was working perfectly ubuntu lucid until I did software update. Since then I have been having limited or no connection at all. Connection strength amount to 12% or so and I can't access Internt, which is only available through my wireless network.
Re-install the drivers dude.
You need to search the Ubuntu forums for your wireless chipset to see if there are issues and how to resolve it.
Most of the time ndiswrapper is a good fall back option and it should help you out in a pinch.
