Wireless Network ADSL settings
satanboy
Psychonaut seven
Paper to Pixels
I have a Wireless Network setup but still need to manually sign into my ISP from each laptop. What should the Home Network settings be to have automatic ISP access?
Modem ??
Just put your user name and password in the router/modem and save it .
I did that. Wireless Network says "No Interet Acces"
If you plug a PC/laptop in to the router does it work with the user name and password in the router ??
If it does work hard wired you will have to set the wirless connection on each wireless PC/laptop including security
You will have to set up a new connection on each wireless device(and set them to default)
When setting up encryption i normally use the key on the sticker on the bottom of the router that way it dont get lost or forgotten.
