wrt54gl keeps on throwing settings away
[OUPA]MrNutz
Vereeniging
Hey ,
i've got a customer with telkom spacestream express.
their gilat (skystar 360e) unit only allows 8 Natted IP's... and they are about 20 users.
so i've decided a while back to use a linksys wrt54gl with ddwrt as router.
did a STATIC ip setup from 360e so that each user gets a IP range 192.168.1.2+ (thus dubble natting in a way)
now the problem comes in: often they get me out to check network failure to find that the Static IP has done a reset to automatic DHCP mode - altho i have verified that the info is SAVED and the UNIT rebooted.
suspecting EMP from lightning - not damaging - but resetting it (hard) . IP and u/p of the linksys AP is always intact tho as i set it afterwards.
any 2c welcome
I had this problem once. It was so weird. I came in one day and all the settings on my router had spazzed out. I set it all up again, and made a backup that included all my settings. I havent had the problem since.
I often get this on my WRT's, after power failures. Also running dd-wrt. Busy testing other firmware.
