Guys - please see if you can give me some advice here.
I want to use my Xbox through my Samsung 2333 as I am sure the picture quality will be better than my Sony vega TV, but I have a few questions.
Firstly I use 2 x 2333SW's on my PC and I don't really want to keep swapping the cables on the monitor to use pc or xbox, does the xbox VGA cable run on standard VGA or is it DVI? If it is standard VGA then I could run the Xbox on Analog on the monitor and PC on Digital, thus avoiding having to change cables, I would just need to change the source on the monitor.
Secondly for sound, can I plug the digital cable that comes with the VGA cable into my pc sound card? How does this work?
Lastly, where is the cheapest way to get a xbox VGA cable, it doesnt have to be original.
O ya, and I was wondering, is it possible to use your 2333 as a TV, not from your pc with a tv card, but though your DSTV decoder?
