Xml help/advise
Ulquiorra
I recently created a website, and need to insert "xml code" into a page. Website was created via muse, and i can't seem to find anyway to insert the xml code into the page.
I have an afridesign package as well, is it possible to insert xml code into your website if the website was made with cm4all site builder?
Any advise regarding this would be super appreciated.
Regards,
Uberwebn00b
When you say "insert XML code" do you mean display it in a formatted way like this:
Code:
<xml>
    <name>Hamster</name>
</xml>
Seems stackoverflow has come to mybb
Your point being? Its a tech forum whats wrong with asking questions like that?
I need to add this to the website: http://api.holidayfactory.co.za/api/package
It is holiday packages from a 3rd party website that needs to be displayed on my website.
Do you want to display the XML in a table (looking like an excel table) ? Maybe this can help?
http://www.w3schools.com/js/tryit.asp?filename=tryjs_ajax_display_table
I don't think OP has any real coding skills and is probably very limited in terms of what they can do with that site builder.
Reading up on cm4all they mention this:
6. Content Syndication with use of industry standards leads to integration possibilities for nearly all RSS and XML feeds including Weather Forecasts.
You might want to look in your online site editor or whatever you use if it mentions something about importing feeds. Otherwise what jouda said, code it yourself if you can.
Regards,
Uberwebn00b
i am assuming you are using adobe muse since you mention muse was used.. this may help..
https://forums.adobe.com/thread/1156663
The question isn't really well-formed/thought out and asked properly. So it can be interpreted in many ways.
It's like me posting "My computer doesn't work, please help!"
There are so many things that can go wrong / can be checked in debugging etc, that it really doesn't matter if I post that on a tech forum or not, it will not get the answer I was looking for.
If the OP asked: "How can I parse XML into a displayable format from 3rd party xyz on the Site Builder abc I'm using" Then everyone would know what they were asking without having to interrogate them like a terrorist for more information.
