Hi all,
I recently bought a D-Link DSL-2750U. Since then the longest that it has held a connection is 18hours.
I looked at the log on the router and since about 6am until now 5pm it has dropped the connection about 6 times.
4 of those were between 6am and 7am this morning.
I came for a Telkom Mega100WR2 which apparently isn't a great router, however that would no drop for days.
Telkom did check out my line not so long ago and they said there was some corrosion on a junction somewhere.
However I still have a bit of a crackle on my line. Keep in my the telkom router didn't seem to have much issue with the crackle.
Thanks for any help or advice!
Info:
Router: D-Link DSL-2750U (Firmware AF_1.00_T05)
ADSL Statistics:
Mode: ADSL_G.dmt
Type: ATM
Status: Up
Downstream Upstream
Line Coding(Trellis): On On
SNR Margin (dB): 163 190
Attenuation (dB): 220 135
Output Power (dBm): 5 -4
Attainable Rate (Kbps): 9888 948
Rate (Kbps): 384 128
D (interleaver depth): 1 1
Delay (msec): 0.13 0.25
HEC Errors: 179 219
OCD Errors: 0 0
LCD Errors: 0 0
Total ES: 20 0
Info:
ADSL Statistics:
Mode: ADSL_G.dmt
Type: ATM
Status: Up
Downstream Upstream
HEC Errors: 179 219
OCD Errors: 0 0
LCD Errors: 0 0
Total ES: 20 0
