32 bit vs 64 bit
Mikeh1
Hi Guys
I wish to change my CCTV to be recorded on my PC (and viewed).
There is a product marketed: "EzCAP 3.5mm RCA to USB 2.0 Audio OGG MP3 WAV Capture Converter Adapter"
However, they claim it will capture 16, 24 and 32 bit. My OS is Windows 10 64-bit.
Will the adapter work and if not, any idea what will?
Mike
:confused:
Hi Guys
Mike
:confused:
This device captures audio not video. The bits they refer to is the audio not Windows.
Thanks, I should've noticed that...... (blushing)..
Any product that may work?
Avermedia, Blackmagic, Compro are video capture companies off the top of my head. Plenty others.
Btw, some devices will only work with their own software. Best to make sure they support Windows standards like vfw, wdm and I forget the latest one. Then you can use any capture software. Check out the reviews.
I did not have it on a dvr.
It is a Lorex LW2231 wireless CCTV camera which was plugged in at the AV of my TV. Would like to put it on my laptop as I have mobility constraints?
I wish I can get this sorted out.....?
