3g antenna?
DANNLER
so in my quest to get uncapped wireless in my area i have failed for now, so having my hauwei 518f wifi router i am getting 2 signal bars the most with telkom 3g go big 20gig deal i have with them... is there any antennas out there that i can use to bring my signal strength up, to reduce my +-350ms ping? or could it be as easy as just to get a better router?
Witbank mpumalanga,
Well when i used to stay in another room in same house, i had better signal and the ping was a little better
We dont have telkom lte in my suburb yet, according to coverage map, and vodacom lte just misses our suburb aswell
I saw that website, but im not to sure what parts to get
Let me post you the link for the product you require.
http://www.antennas.co.za/Products/ProductList?special=35
http://www.antennas.co.za/Products/ProductList?cat=LTE
Alternatively look at the Poynting routers which come with the appropriate kit.
I would suggest giving them a call and explain to them which router you have and say that you want a kit to boost your LTE signal. The kit should comprise of cables, antenna, indoor / outdoor mounting kit, "pigtails" for connecting to the router with the correct connectors.
They are a pretty helpful group.
