ADSL Stellenbosch issues!
pieterv
been a difficult few weeks - speeds under 0,3MBPS from 18h00 to 23h00 every night. latency tests 200+. daytime on 4meg line runs steady at 3 download and 0,3 upload mbps. for a few weeks in july almost no resolvable speed or connection - telkom works in our street all the time and loads of new exchange boxes fitted but just no speed on adsl
jonkershoek rd mosterstdrift - absolutely terrible. at least now at times I get 3mbps but at night it chokes to 0,2 mbps
new switchgear installed and adept my provider- 4 to 10 m line
just to freak me out now church street has gone down as well - it blue service provider. seems telkom likes working here and other construction we get interrupted service
1 Meg uncapped from Afrihost. Flawless.
The line has gone down probably for 3 days so far this year. It seemed to then be Telkoms fault.
Seems that I'm having issues again, standard congestion symptoms with high latency after hours. Central Stellenbosch.
Having issues as well today. High latency with spikes every now and then. Getting around 170ms traceroutes to local servers where it should be 10 - 50 ms. International is even higher and the spikes/packet loss make trying to do anything more than browse nigh impossible.
I'm in central Stellenbosch near PnP. I've had this issue before, but they resolved it after spending some time bugging TelkomZA, but it seems to be back.
Something also wrong with my connection today, going to phone telkom tomorrow because I can barely browse on both my openweb and my afihost account.
Often frustrated by high latency, cannot yet pinpoint it - need to develop my understanding, admittedly. Sometimes download speed very low.
1.024MB ADSL
021887xxxx
In Stellenbosch, Uniepark
Download speed OKish (840kbit/s), ping 145ms to Johannesburg server - Mybroadband Speedtest
traceroute to telkom.co.za (196.43.22.222), 64 hops max, 52 byte packets
1 192.168.0.1 (192.168.0.1) 2.504 ms 3.436 ms 2.133 ms
2 105-236-8-193-esr-lo.mtnbusiness.co.za (105.236.8.193) 503.316 ms 410.827 ms 358.506 ms
3 ipc-recieve-tb-2a.mtnbusiness.net (41.181.54.86) 389.074 ms 392.435 ms 426.189 ms
4 tb-dca-2.za--qux-c.za.mtnbusiness.net (41.181.198.188) 379.673 ms 409.631 ms 409.645 ms
5 unc-cpt-1.mtnns.net (196.44.18.8) 409.413 ms 409.441 ms 409.135 ms
6 tb-pr-1.za--tb-cr-2.za-a.mtnns.net (196.44.18.143) 409.597 ms 409.182 ms 277.319 ms
7 wblv-ip-se-2-gw.telkom-ipnet.co.za (196.25.165.197) 335.987 ms 409.295 ms 409.190 ms
8 196.43.25.205 (196.43.25.205) 330.329 ms 388.713 ms 409.722 ms
9 196.43.39.162 (196.43.39.162) 409.294 ms 309.954 ms 409.736 ms
10 rrba-ip-bssr-1-ge-2-48.telkom-ipnet.co.za (196.43.23.6) 407.558 ms 408.910 ms 409.710 ms
11 nbsc-ip-bssr-2-atm-5-0-0-1.telkom-ipnet.co.za (196.43.23.34) 280.691 ms 409.123 ms 259.934 ms
12 nbsc-ip-rcache-1-vif0.telkom-ipnet.co.za (196.43.22.222) 354.811 ms 407.647 ms 411.097 ms
In Stellenbosch, Welgevonden on 2Mbps. Speed is actually OK. ADSL connection in this area was down for a few hours at least 6 or 7 times this year.
Been having trouble for the last 3 weeks or so. Slow download speeds, videos generally have to buffer or stream at low bitrates. Latency also not great, but that affects me less.
Speedtest.net to local servers: ~30ms ping (but >300ms sometimes), 0.8-1.5Mbps dl, <0.5Mpbs ul.
Stellenbosch central, near Builders Express
021883xxxx
4Mbps
WebAfrica 4Mbps uncapped
Evenings
Traceroute (I'm assuming something went wrong?):
1 1 ms 1 ms <1 ms MyDslModem.local.lan [192.168.1.1]
2 * * * Request timed out.
3 * * * Request timed out.
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 196 ms 154 ms 119 ms nbsc-ip-rcache-1-vif0.telkom-ipnet.co.za [196.43.22.222]
Info from my router:
Downlink rate 4096000
Uplink rate 512000
SNR (downstream) 19.0 dB
SNR (upstream) 13 dB
Line Attenuation
(downstream) 6.5 dB
Line Attenuation
(upstream) 5.0 dB
No Problem in Onder-Papegaaiberg
We had congestion problems in Onder-Papegaaiberg from September 2012. Telkom eventually resolved the problem in April 2013 (at least my line has been running fine since then). Max line speed available at the exchange is 4mbps though.
Your Latest Results
Last Result:
Download Speed: 3633 kbps (454.1 KB/sec transfer rate)
Upload Speed: 337 kbps (42.1 KB/sec transfer rate)
Latency: 57 ms
14 August 2013 23:25:04
021886xxxx
4Mbps
WebAfrica Uncapped
Code:
Tracing route to telkom.co.za [196.43.22.222]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  192.168.21.254
  2     1 ms    <1 ms    <1 ms  192.168.21.1
  3    13 ms    12 ms    16 ms  196-215-192-1.dynamic.isadsl.co.za [196.215.192.1]
  4    15 ms    15 ms    14 ms  cdsl1-ctn-vl2376.ip.isnet.net [196.38.72.205]
  5    15 ms    15 ms    14 ms  196.35.115.128
  6    32 ms    15 ms    46 ms  168.209.6.12
  7    84 ms   166 ms    95 ms  168.209.2.130
  8    13 ms    13 ms    13 ms  196.25.247.25
  9    14 ms    14 ms   169 ms  196.43.25.205
 10   104 ms    38 ms    38 ms  196.43.39.162
 11    36 ms    36 ms    35 ms  rrba-ip-bssr-1-ge-2-48.telkom-ipnet.co.za [196.43.23.6]
 12    40 ms    40 ms    58 ms  nbsc-ip-bssr-2-atm-5-0-0-1.telkom-ipnet.co.za [196.43.23.34]
 13    96 ms    55 ms    38 ms  nbsc-ip-rcache-1-vif0.telkom-ipnet.co.za [196.43.22.222]
Trace complete.
Code:
# adslctl info --stats
adslctl: ADSL driver and PHY status
Status: ShowtimeRetrain Reason: 0
Channel: FAST, Upstream rate = 512 Kbps, Downstream rate = 4096 Kbps
Link Power State: L0
Mode:                   G.DMT
Channel:                Fast
Trellis:                ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):       14.7            14.0
Attn(dB):       7.0             3.5
Pwr(dBm):       -2.8            4.3
Max(Kbps):      9216            1136
Rate (Kbps):    4096            512
So it seems something is wrong again:
Code:
  1   281 ms   305 ms   329 ms  41-132-42-1.dsl.mweb.co.za [41.132.42.1]
  2   320 ms   321 ms   305 ms  197-84-96-210.cpt.mweb.co.za [197.84.96.210]
  3   240 ms   261 ms   289 ms  197-84-2-2.cpt.mweb.co.za [197.84.2.2]
  4   290 ms   299 ms   305 ms  197-84-5-226.cpt.mweb.co.za [197.84.5.226]
  5   248 ms   255 ms   283 ms  tengig0-0-0.cpt-pr-2.mweb.co.za [197.84.4.165]
  6   313 ms   309 ms   317 ms  cpt.telkom-ipnet.co.za [197.84.4.21]
  7   363 ms   305 ms   257 ms  196.43.25.205
  8   309 ms   343 ms   343 ms  196.43.39.162
  9   506 ms   517 ms   507 ms  rrba-ip-bssr-1-ge-2-48.telkom-ipnet.co.za [196.43.23.6]
 10   471 ms   427 ms   331 ms  nbsc-ip-bssr-1-atm-5-0-0-1.telkom-ipnet.co.za [196.43.23.30]
 11   378 ms   444 ms   462 ms  nbsc-ip-rcache-1-vif0.telkom-ipnet.co.za [196.43.22.222]
Trace complete.
Something was seriously wrong earlier today / this evening in Stellenbosch.
And like magic it is all back to normal again now...
I'm also having congestion slight issues in Die Boord, Stellenbosch. Are code is 021 887 xxxx.
My download speeds only reach 4Mbps at around 03:30 and then start to decline again from 06:30. For most of the day it would typically be anything from 2Mbps-3Mbps, and I've tried MWEB 4Mbps Uncapped, WebAfrica prepaid and now I'm using OpenWeb Gamers' King Uncapped 4Mbps.
* Click for full size image
My latency is OK and shows no signs of congestion:
Code:
Tracing route to www.google.co.za [74.125.233.55]
  1     2 ms     1 ms     2 ms  mikrotik.tuis.local [192.168.11.1]
  2     3 ms     2 ms     3 ms  192.168.91.1
  3    15 ms    14 ms    14 ms  196-210-150-1.dynamic.isadsl.co.za [196.210.150.1]
  4    17 ms    17 ms    18 ms  cdsl2-ctn-vl2276.ip.isnet.net [196.38.72.125]
  5    18 ms    18 ms    18 ms  196.35.115.136
  6    31 ms    18 ms    17 ms  168.209.6.12
  7    45 ms    42 ms    40 ms  168.209.100.13
  8    41 ms    41 ms    41 ms  168.209.1.179
  9    42 ms    41 ms    54 ms  74.125.49.66
 10    41 ms    50 ms    43 ms  64.233.174.21
 11    95 ms    41 ms    41 ms  jnb01s01-in-f23.1e100.net [74.125.233.55]
Trace complete.
Since its weekend, the download speed is also not that bad either:
* Ignore this ping result.
A colleague of mine is having much worse congestion issues in the upper part of Die Boord and the DSLAM is like 10m away from his modem! I've never seen line attenuations as low as his:
1.0dB downstream and 0.5dB upstream line attenuation
His latencies are also OK, but he's unable to even get 2Mbps on his 4Mbps account.
I'll ask him to post later on Monday.
high latencies from Rozendal (021 886 xxxx) this morning
Code:
Tracing route to www.google.co.za [173.194.65.94]
  1    <1 ms    <1 ms    <1 ms  192.168.10.1
  2    11 ms    10 ms    10 ms  105-236-8-193-esr-lo.mtnbusiness.co.za [105.236.8.193]
  3    36 ms    36 ms    36 ms  ipc-recieve-tb-1a.mtnbusiness.net [41.181.53.150]
  4    11 ms    11 ms    12 ms  tb-dca-2.za--qux-c.za.mtnbusiness.net [41.181.198.188]
  5    12 ms    12 ms    11 ms  compj-cpt-1.mtnns.net [196.44.18.2]
  6   155 ms   155 ms   156 ms  jp-nt-1--pe-ad-1-a.mtnns.net [196.44.31.113]
  7   165 ms   165 ms   166 ms  am-cr-1.nl--ls-cr-2.uk-a.mtnns.net [196.44.31.183]
  8   204 ms   164 ms   164 ms  am-tpr-1.nl--am-cr-1.nl-a.mtn.net [209.212.111.141]
  9   165 ms   164 ms   163 ms  core2.ams.net.google.com [195.69.145.100]
 10   164 ms   164 ms   164 ms  209.85.254.95
 11   307 ms   306 ms   306 ms  72.14.238.69
 12   169 ms   168 ms   187 ms  216.239.49.38
 13     *        *        *     Request timed out.
 14   168 ms   168 ms   168 ms  ee-in-f94.1e100.net [173.194.65.94]
Trace complete.
and not even completing to Telkom:
Code:
Tracing route to www.telkom.co.za [165.143.158.8]
  2    10 ms    10 ms    10 ms  105-236-8-193-esr-lo.mtnbusiness.co.za [105.236.8.193]
  3    12 ms    11 ms    11 ms  41.181.221.254
  4    12 ms    76 ms    13 ms  tb-dca-2.za--qux-c.za.mtnbusiness.net [41.181.198.188]
  5    12 ms    12 ms    12 ms  unc-cpt-1.mtnns.net [196.44.18.8]
  6    12 ms    12 ms    12 ms  tb-pr-1.za--tb-cr-2.za-a.mtnns.net [196.44.18.143]
  7    31 ms    32 ms    31 ms  wblv-ip-se-2-gw.telkom-ipnet.co.za [196.25.165.197]
  8    12 ms    11 ms    12 ms  196.43.25.205
  9    56 ms    56 ms    56 ms  196.43.51.78
 12     *     telkom-sa-tienet-gw.telkom-ipnet.co.za [196.25.54.62]  reports: Destination net unreachable.
Trace complete.
Anyone else having issues tonight? I'm barely getting 1Mbps on my 4Mbps Afrihost GamersKing uncapped tonight!
I'm in Die Boord (021 887 xxxx).
My latency is still fine.
I'm having issues only at night with international only. Ping to local servers is stable and low at all times, and international servers during the day are stable at 300ms. But at night, the international pings fluctuate heavily from 300 - 1500ms. Not sure if this is a general issue at the moment, I've been a bit out of the loop.
Definitely having throughput issues. I can't get over +-81kB/s on my Afrihost or Internet Solutions accounts. Upload is fine.
Earlier today I was maxing out my 2mb line.
Serious issues in Rozendal atm:
On my 4MBs capped account from the Afrihost clientzone:
Current Downstream Sync
509kbps
The current download speed established between the DSLAM and your modem.
