"affordable" 802.11ac WiFi APs?
Pada
Stellenbosch
Hi everyone,
Do you know where I could find 802.11ac/n WiFi AP's that doesn't cost like R2k+ ?
I don't want to buy an expensive 802.11n WiFi AP now while 802.11ac is already available.
Currently the cheapest 802.11ac router that I could find is the Linksys EA6500 @ ~R2k
At this moment I have a TP-Link WR841ND, running DD-WRT, but I'm having wireless issues with my Samsung Galaxy S2 (where the first connection never works) and Macbook Air (which stops functioning and cannot reconnect until I restart the AP).
Update:
I see Uniterm Direct has the TP-Link AC1750 for like R1700 (incl VAT), but I'm questioning its compatibility and performance :(
Thanks Space_Chief!
Unfortunately that router didn't get good user reviews, but then again, the Linksys EA6500 didn't receive that many great reviews either.
Uniterm sells the TP-Link variant. Prices are reasonable and local support is a plus.
www.dbg.co.za
Local support is overrated. ;)
I would just snipe bid on one of the better models to get the thing as cheap as possible, if price is a priority. Tech is always a gamble. But so far I've always been lucky and things tend to fail, after the warranty ends anyway.
