Are you connected to 5GHz Wifi? I found that my phones used more power conntected to a 5GHz network than on LTE standby. On the Mi A2 Lite, it was huge! Like 0.7%/hour on a 5GHz network.I'm finding the battery drain even with mobile data turned off and solely connected to Wifi.
I should maybe do a test this weekend with the SIM removed and see what the drain is like then.
Redmi Note 5 Pro here. Connected to 5GHz. Even with Wifi turned off, the drain was unusually high.Are you connected to 5GHz Wifi? I found that my phones used more power conntected to a 5GHz network than on LTE standby. On the Mi A2 Lite, it was huge! Like 0.7%/hour on a 5GHz network.
Hi,
I trust all is well.
The battery drain is not related to the APN. The only thing the APN is doing is to determine which network path the device will use for data connectivity.
Battery drain in a smartphone can be caused by multiple factors but not the APN.
I trust the above is clear.
Kind Regards,
Ntsika
Afrihost.com
Pure Internet Joy!
Update:
So I spent the last week gathering data for bug reports on my Mi A2 Lite, because Afrihost was moaning about the accuracy of Accubattery and the app itself possibly causing the battery drain.
I uninstalled Accubattery, ran the standby tests again, pulled the bug reports, to get the same results again, and sent it them, just to get this response:
And literally, all I did between tests is change SIMs/APNs and reboot the phone. Apparently, the concept of cause and effect does not exist.
@AfriMan why is Afrihost going through such denial, just to not have to deal with an issue?
Thanks for raising this issue. To my knowledge it wouldn't be possible for the APN name itself to consume power in a different way from another APN.
Please kindly note that the Afrihost APN service itself cannot be compared with other networks as it runs simultaneously with the MTN network and therefore explains why it would consume more power. There is more processing that your device needs to do in order to connect to the Afrihost APN and We cannot do anything about this unfortunately.
Maybe you need to chat to the agent who said this:
/thread necro
I recently ported from CellC to MTN and immediately switched over to the Afrihost APN. My battery life has been atrocious vs CellC LTE. I'm usually at 60% battery when I get home from work. Now it's around 30%.
@AfriGuy @AfriNatic has anything ever come from this investigation?
I'm using a OnePlus 6. I haven't tried it yet, but will switch over now and see how it goes.Hi,
What device are you using? Does the battery drain also happen on the MTN apn?
I think I've found the culprit. The "sim toolkit" which android phones install from the sim card. Since killing the process my battery drain on the afrihost APN has been fixed. Maybe other people with the same issue should give it a try?Hi,
@AfriNatic i noticed that even when my device connects to a WiFi network and uses WiFi calling, the public IP assigned on the lte side is still pingable from the outside until I change the APN back to mtn, so I'm pretty convinced at this point that my post above is the cause of the high battery drain while on the afrihost APN.
Would be interesting to see how much it helps having a CGNAT ip if possible.
Hi,
Sorry for the late reply. I'm working through all the messages and mentions.
Do you have a public IP address currently on your mobile sim? I don't think it will do much but yet it's an android thing that even while connected to wifi the session remains open. I noticed it with my own android and account.
Yep, I always get a public IP handed out, and not a CGNAT one.
The reason I suspect that this is the cause of high battery usage is because of all the random IPs/bots on the internet that's pinging the IPs assigned to our phones, and port scanning, etc, which causes the LTE to always be active, using more battery power. With a CGNAT IP this wouldnt happen as your phone is not pingable/accessabile from the public internet, so the LTE interface on the device can sit idle when not being used, like what happens with the normal MTN APN.
I can literally only change the APN setting, and no other setting on the phone and the battery usage more than doubles, this is the only reason I can think of.
