My line stays synced but the PPP connection seems unstable. Two days ago I came home to find the DSL light on but no internet, checked the router and it was synced but the router had no IP address. I rebooted it, worked fine first time, 5 minutes later the PPP connection dropped again and the line stayed synced. I had that issue all night, then yesterday it took one reboot and it was fine. Now I came home to find the same situation, but it seems okay for now.
It's kind of like the router is on dial on demand mode but it is set to always on. It happens with telkom and afrihost accounts. Router is a DLink DSL-2750U fw version AF_1.60_R01. Every time I check the logs on it when this happens it says "PPP: Start to connect ... " every 30-40 seconds or so, but never connects.
First time this has happened. Not sure if it's my side or if there's anything I can do about it.
As I clicked post it happened again. This time I just unplugged the phone line and plugged it back in and it connected fine.
Here's the log:
Code:
Downstream Upstream
Line Coding(Trellis): On On
SNR Margin (dB): 145 140
Attenuation (dB): 440 255
Output Power (dBm): 108 101
Attainable Rate (Kbps): 6560 912
Rate (Kbps): 2048 512
Here's the log:
Code:
Jul 18 00:00:28 daemon notice syslog: PPP: Start to connect ...
Jul 18 00:00:28 user info kernel: device wl0 entered promiscuous mode
Jul 18 00:00:28 user info kernel: br0: port 5(wl0) entering forwarding state
Jul 18 00:00:29 daemon crit syslog: PPP server detected.
Jul 18 00:00:29 daemon crit syslog: PPP session established.
Jul 18 00:00:29 user warn kernel: wp1=3c wp2=00
Jul 18 00:00:29 user warn kernel: e127wp1=00 wp2=3c
Jul 18 00:00:29 daemon crit syslog: PPP LCP UP.
Jul 18 00:00:49 daemon crit syslog: Received valid IP address from server. Connection UP.
Jul 18 00:01:00 user warn kernel: wp2=00
Jul 18 00:01:01 user warn kernel: wp2=3c
Oct 11 16:44:12 user alert kernel: Intrusion -> IN=ppp0 OUT= MAC= SRC=41.235.213.190 DST=41.243.42.38 LEN=60 TOS=0x00 PREC=0x00 TTL=44 ID=47630 DF PROTO=TCP SPT=4058 DPT=23 WINDOW=5808 RES=0x00 SYN URGP=0 MARK=0x8000000
Oct 11 16:44:57 user alert kernel: Intrusion -> IN=ppp0 OUT= MAC= SRC=186.236.128.148 DST=41.243.42.38 LEN=60 TOS=0x00 PREC=0x00 TTL=53 ID=4439 DF PROTO=TCP SPT=2121 DPT=23 WINDOW=5808 RES=0x00 SYN URGP=0 MARK=0x8000000
Oct 11 16:49:21 user alert kernel: Intrusion -> IN=ppp0 OUT= MAC= SRC=60.191.153.156 DST=41.243.42.38 LEN=40 TOS=0x00 PREC=0x00 TTL=101 ID=256 PROTO=TCP SPT=6000 DPT=1433 WINDOW=16384 RES=0x00 SYN URGP=0 MARK=0x8000000
Oct 11 16:52:29 user alert kernel: Intrusion -> IN=ppp0 OUT= MAC= SRC=42.121.236.2 DST=41.243.42.38 LEN=40 TOS=0x00 PREC=0x00 TTL=98 ID=256 PROTO=TCP SPT=6000 DPT=1433 WINDOW=16384 RES=0x00 SYN URGP=0 MARK=0x8000000
Oct 11 16:52:34 user alert kernel: Intrusion -> IN=ppp0 OUT= MAC= SRC=122.225.106.165 DST=41.243.42.38 LEN=40 TOS=0x00 PREC=0x00 TTL=99 ID=256 PROTO=TCP SPT=6000 DPT=1433 WINDOW=16384 RES=0x00 SYN URGP=0 MARK=0x8000000
Oct 11 16:55:32 daemon crit syslog: Clear IP addresses. Connection DOWN.
Oct 11 16:55:32 daemon crit syslog: Clear IP addresses. PPP connection DOWN.
Oct 11 16:55:41 daemon notice syslog: PPP: Start to connect ...
Oct 11 16:56:00 user crit kernel: Line 0: ADSL link down
Oct 11 16:56:00 user warn kernel: bcmxtmcfg: XTM Link Information, portid = 0, State = DOWN, Service Support = ATM
Oct 11 16:56:00 user warn kernel: bcmxtmcfg: Connection DOWN, LinkActiveStatus=0x0
Oct 11 16:56:07 user crit kernel: Line 0: xDSL G.994 training
Oct 11 16:56:11 user crit kernel: Line 0: ADSL G.992 started
Oct 11 16:56:13 user crit kernel: Line 0: ADSL G.992 channel analysis
Oct 11 16:56:17 user crit kernel: Line 0: ADSL link up, fast, us=512, ds=2048
Oct 11 16:56:17 user warn kernel: bcmxtmcfg: XTM Link Information, portid = 0, State = UP, Service Support = ATM
Oct 11 16:56:17 user warn kernel: bcmxtmrt: MAC address: 84 c9 b2 d7 a8 d0
Oct 11 16:56:17 user warn kernel: [DoCreateDeviceReq.2367]: register_netdev
Oct 11 16:56:18 user warn kernel: [DoCreateDeviceReq.2369]: register_netdev done
Oct 11 16:56:18 user warn kernel: bcmxtmcfg: Connection UP, LinkActiveStatus=0x1, US=512000, DS=2048000
Oct 11 16:56:18 daemon notice syslog: pppd 2.4.1 started by admin, uid 0
Oct 11 16:56:18 daemon notice syslog: PPP: Start to connect ...
Oct 11 16:56:27 daemon crit syslog: PPP server detected.
Oct 11 16:56:27 daemon crit syslog: PPP session established.
Oct 11 16:56:27 user warn kernel: wp1=3c wp2=00
Oct 11 16:56:27 user warn kernel: e127wp1=00 wp2=3c
Oct 11 16:56:27 daemon crit syslog: PPP LCP UP.
Oct 11 16:56:27 daemon crit syslog: Received valid IP address from server. Connection UP.
