CandyMan_ZA
Hi, I have just purchased a AR821-2CKT001 8CH Combo Kit from Esquire and am having difficulties setting up the E-mail and Dropbox. I have tried two separate SMTP setups. On my LAN at home I have a two SMTP mailboxes set up on my PC, as well as on my mobile phone, both work. I have tried setting up the AR821-2CKT00 to use either of these and neither is working. I tried using smtp.mweb.co.za port 25 and pop.pixelsandbits.co.za port 587 with authentication (my personal mailbox). Both of these work on my PC and mobile phone on my LAN over ADSL.
When I test the E-mail with my MWEB mailbox I get an error “Please check your input!”
On my other mailbox, kevin at pixelsandbits.co.za I also use on my PC and mobile phone which work I get this error on the “Failed,E-MAIL can’t be sent!”
I am also having difficulty setting up my Dropbox. I assume it is related to the problem I am having with the E-mail? I get this error “Activation fails, check the network configuration and parameters.”
According to their FAQ they refer to a GMail mailbox and SMTP server, I haven't tried using my GMail mailbox, I will try this this evening.
I have asked KGuard Support for help but still waiting a response.
Anyone got some experience on setting this up?
Kevin
Kevin
