I believe... They have two cameras spaced several km's apart, using NPR (Number Plate Recognition) tech. They then use the date-stamp from both cameras to see if your average speed (when you pass the second camera) has been higher than the speed limit. I remember them trialing this between PMB and DBN a few years ago. From what you are saying, it sounds like its now active all the time?
In JHB just drive without number plates because the Metro pigs are lazy![]()
That way you still have the risk (legal & practical) but forfeit the gains (getting there earlier). Brilliant.Just pull over for 5 mins and then you can do 140 again![]()
100% pure sarcasmBrilliant.![]()
Or just drive the speed limit?
Now there is a novel idea!
I applaud him for his rigourous Empirical Research.a 100km/h limit imposed. A colleague has a fine sitting on his desk to prove it.
Its pretty solid afaik. The algo is likely to be a ANN w/ backpropagation. If correctly set up + good camera it should be near bullet proof. The one thing that makes it a bit sketchy is the different plate designs per province. The ANNs don't particularly like stuff like that, but should still cope.I am concerned about the accuracy for it.
I know there is a commercial demo room for this tech along the N1 somewhere in midrand. An acquaintance of mine went to for business & said its pretty impressive.
