airborne
- Jul 13, 2007
As many people have suggested have you tried pulling the fuses till you find which circuit is causing the drain?I meant I have reached out to get a quote. Still waiting for feedback.
It's a simple process and often once you know where to look the culprit is easy to see, like a loose connection or rubbed wire.
A good auto electrician may find the issue quite easily but even then not guaranteed and they are not cheap. And it appears you don't have an auto electrician that you already use and can trust, a dodgy auto electrician can start costing the earth, many technicians these days only know how to replace parts and very little about diagnostics.
