Battlefield: Bad Company 2 Problem/Bug Please Help!
korn101
Hi
Since my install of BC2 Yesterday, I started playing, I had some tearing issues that I fixed, but I still cant see any buildings :( all of the Destructable buildings are invisible.. :( Please Help If you know what it might be!!!
Im updating my GPU Drivers now, I have tried Re-installing a few times but it just doesnt fix it...
Setup:
-Sparkle 8600gt
-Intel E7400 Core2Duo
-2.5gb RAM
-Intel D945GCL Motherboard, or GCNL
Don't know what it could be mate.
Maybe someone can help me? I am unable to locate or join any local servers! Can anyone help, please?
My first bit of advice would be to do all the normal stuff;
Make sure you have all the latest drivers (don't use Sparkles drivers, get the latest drivers from Nvidia) and the latest sound drivers, the latest directX, the latest service pack for your XP or VISTA and with 7, do all the windows updates.
Seriously, that should fix it.
The problem is probably graphical (think about it) so graphics drivers should fix it.
Hi
Setup:
-Sparkle 8600gt
-2.5gb RAM
Did the new graphics drivers make a difference? Have you tried lowering your graphics quality preference a little and disabling AA, etc?
I doubt it's simply a general bug, a few of my friends pre-ordered it and haven't had any issues. Maybe it doesn't like your graphics card (seeing it is below the minimum requirements).
Yeah, try pushing everything to either lowest or off, play the game if it's fine, then start moving the things 'up one' and trying again, till you find the problem.
Dude you need to into your documents folder then the bfbc2 folder look for settings.ini and edit it with notepad and change the dx version to 9.
Your gpu needs upgrading badly though.
Its not bellow the minimum req.
Those requirements are just guidelines man.
You don't follow them "as word of god"
You know that if you have minimum settings, don't buy the game or I wouldn't.
Word of the day for you: UPGRADE!
okay i managed to fix it..
I just deleted the BFBC2 folder in My Documents.. And Strangely.. That Fixed it..
O_O weird bug... Just dissapeared now..
Okay I found what was causing the problem.
It was Nvidia Stereoscopic. Don't know why.. But just turn it off, even when its not even rendering 3d, It will still make it glitch out.
okay got the game yesterday
its me and punkbuster again, why they insist on this failed piece of extra software its beyond me why dont they just build it in the game itself.
But anyway back to my problem.
I have Windows seven prof 64bit.
I installed the game, downloaded the patch and downloaded the updater punkbuster.
Added the game to the list but changed the default path of where pb wanted to install causei install my games on a different drive for incase my windows crash.
I pointed to the new folder the updater downloaded two files and confirmed that pb is now updated.
When I enter the game and login I cannot see any servers but it works if I just say play game now and it will find a game(why cant I see any servers on the list)
Now all go fine untill I have to shoot someone then PB throws me out and says that I have to visit evenbalance and support for updated drivers, or I get a pockets lost error.
Now this tells me that PB cant work properly and either the files are not working or my pb dont recognize at all.
I have removed the game from PB folder and list.
Re-inlisted and downloaded new updated files.
I have maunually downloaded th files from evenbanlance to my pb folder in BFBC2 installed pb folder.
Could someone help please
