Does anyone have advice regarding routers compatible with the Telkom Fixed LTE network?
Which is the best router you can buy that supports the telkom LTE network?
Any lte router will get the job done, but for the best results you may want a router that supports the 2300mghz frequency since that is the band containing the most spectrum.
Telkom used to bundle the Huawei b315-936 or b525-65a with their contract offerings since both support the necessary frequencies to operate on their network. The b525 supports lte advanced which in theory means that it should be capable of achieving higher speeds if the network supports that function.
Good reception is more important in achieving high connection speeds than buying the 'best' router.
