Billion ADSL Router problem
Isengard
Hi, I'm having some difficulty setting up my Billion 800VGT router in Windows 7. The ADSL line is not installed yet but I have the router now so I figured I could get it set up so long. My problem is i cant connect to it in any way. I set my network to obtain an IP automatically through DHCP. which it does successfully, the router and PC are connected and communicating. The default ip is supposed to be 10.0.0.2 but I cant connect to the web interface with either chrome, firefox or ie8. I tried pinging the ip and get ''destination net unreachable''. I've tried disabling the windows firewall, my antivirus, on luck. Any help will be appreciated.
You need to run the config through a wire, this is for security reasons.
The default IP for config on a Billion router/modem is usually 192.168.1.254
Problem solved, this is not a new router, was my Dads. The default ip according to the manual is 10.0.0.2 but I just did the ipconfig /all and noticed the DHCP server ip was not 10.0.0.2. I tried resetting it to factory settings but that clearly didn't work. Need to try it again since the passwords were changed too and I don't have them. :/ thanks guys
Hi please reset your router for 8 seconds and after that switch it OFF and ON.Make sure your computer is using a DHCP and then you can login to the router and set it up.The default IP address is 10.0.0.2.The username and password is admin.
