BSoD help?
AntOny_zA
hi, new to this forum. if this isnt the right place to post can a mod please move it, thanks.
i was playing crysis 2 yesterday for maby 3 hours then all of a sudden BSoD!! aaah. didnt see the error message turned off and booted up again. It booted and i launched the game, maby 5 seconds later BSoD again. But then my pc wouldnt boot into windows, there was power, mobo, gpu fans etc all on but just a black screen. i notice the mobo didnt beep twice like normal so ram problems i assume?! i left it off over night now the thing works fine. gpu got to about 80 deg.
Wanna know if theres a specific reason it didnt boot up the second time?
Cpu:i7 860 @ 2.8 GHz socket 1156//Ram:kingston DDR3 4gb 1333fsb cl9 x 2//Gpu:Inno3D geForce gtx 560ti @256 bit, 1GB DDR5,822MHz//HDD:1tb segate 7200 rpm//mobo:intel DP55WB//Psu:Antec TruePower 750w//Case:CM 692II advanced
Try www.ma-config.com there is a tab for BSOD.
Right place dude! :)
If it wasnt beeping on bootup - you could run Memtest to check your RAM for any faults.
Otherwise, Id just wait for the problem to happen again - might have just been heat that caused something to malfunction. If thats the case though, it will happen again.
Crysis - gimme!
