CCTV over Fibre
nxpress
Fibrehoods will be doing my complex Fibre infrastructure installation and we would like to piggy back of this Fibre for a complex cctv system. The problem is Fibrehoods has suggested that it would be very expensive to do so.
Has anyone had a cctv system installed in the complex over Fibre ?
Any advice or preferred contractors that can assist?
The expensive part is taking the coax or Ethernet signal from the camera and converting it to an optical signal. One such box will cost at least as much as the camera itself.
depending on fibrehoods infrastructure (GPON/AE) this is actually easy to do, hardest part is actually supplying the cameras with power because they tend to be located in remote locations :-)
They are actually under 1k
Piggy backing on the PON network is generally not worth it, as you would need independent fibrehoods lines for each cluster of cameras which then links back to the fibrehoods pop, so you would need to tie them into a layer2 network somehow with an ISP from there. It usually makes more sense to run internal infrastructure and then uplink it with a fibrehoods line.
Getting the independent fibre lines is possible, taking that into consideration, is it still worth it? Considering that we would still have to trench in power cables for supply?
This is what I think will take up a lot of the cost as well.
No, media converters are not that expensive.
You don't use media converters with PON, if that is what fibrehoods runs
From experience power to the camera locations (if they remote, IE along a fence) is the costly part, the actual fibre becomes insignificant compared
In the end i really think it depends on the architecture required in the estate if you roll your own or use fibrehoods.
Independent fibre lines which you then have to pay an ISP for every month? If you have to run power, might as well run fibre internally at the same time.
