Cell C connector software for a speed stick
Nduh_Majoka
Hi guys, i hope you'll help. my speed stick autorun file has stopped working and i've been up and down with cell c and they cant help me even if i'm still under warrant. if anyone with a desktop connector software for ZTE-MF190 and not the update please that file you'll find it inside the modem drive to install(.exe). i have 20gb that i'll loose this month if i don't use this stick please share it using Dropbox to [email protected]
Thnx for your response, if i may ask this won't have any issues with cell c connection?
I had a sort of similar problem with my Nokia CS-19 Speed Stick where I couldn't complete the installation on Windows 8 64-bit. I downloaded the UPDATE software, EXTRACTED the files to a folder, RAN the UPDATE file as an ADMINISTRATOR. I then opened FILE-> SWITCH TO ADVANCED MODE, selected all the files needed to flash speed stick and clicked FLASH.
My speed stick was flashed and in about 15-20 I was able to install the new Dashboard and it works like a charm. You HAVE to UPDATE the firmware.
Delete the Old software completely for the new software to work
Hi have a problem with my mf668.When iI got it I installed it but then said upgrade software.so did that and now doesnt want to install drivers.Ive tried cell c download and nothing.at this stage i'm using the vodacom dongel with my cell c sim via dail up but its too slow.HELP!!!!!! plz in novice terms lol
