Cell C Fixed LTE Issues
GTDae
I am on Axxess Cell C Fixed LTE, I am based in Centurion. Today the connection is almost unusable. I am connected with good signal, but up and down speeds are really low.
You didn't say what troubleshooting you already did so I'll start the basics
Plug it in and out and see how that does
Restarted the router a few times and the pc in case there was some background processes that I couldn't see. But even in the resource monitor shows ~100kbps network usage before and after I run speed tests.
I sometimes forget most people don't have extensive IT backgrounds....
Meh
100kbps shouldn't affect things, whats the chances of you being outside of your FUP?
Meh
Its prepaid, so I don't think FUP should come into play. 53Gb left... It's been happening on and off in my area lately. But today I am on a deadline so of course it's giving me crap...
Grab the Tower ID, Then see if you disconnect and reconnect if you can get on a different tower?
I'm temporarily relocating to Starbucks. I'll give it a try a bit later.
