cell c LTE versus cell c fixed LTE
rory
#1
Hi.
Is there anyone who can enlighten me on the technical difference between prepaid cell c LTE and cell c fixed LTE.
I have had a prepaid cell c sim in a router with roaming turned OFF at a fixed location and using uptime robot have had 100% uptime for over 2 weeks at least. It appears to be connecting to a cell c tower. If I do a manual search i find cell c 4g signal and it connects.
I have had downloads speeds between minimum of 15mb up to 50mb and uploads between 7 and 21mb.
The cell c fixed LTE map says no fixed LTE in this area at all.
How is this possible. Does it use another technology or are they blocking some towers or what other reason could there be excellent cell c LTE signal (100%) but no fixed LTE.
I have asked afrihost, axxess and cell c this question but no one can tell me the difference. Just I do not have coverage.
Other answers are one is LTE the other is FIXED LTE. Not good enough for my inquiring mind.
thanks
ginggs
Super Grandwizard
Super Moderator
#2
https://www.cellc.co.za/cellc/lte-home
WHAT IS FIXED LTE?
Cell C brings you reliable and super-fast internet for your home or office. It provides connectivity to all Wi-Fi enabled devices when connected to a LTE-enabled CPE Router. Connect up to 32 devices on a CPE Router making it easier for you and your staff to all be connected with super-fast internet.
With LTE being faster than 3G, you will experience faster online gaming, video streaming, music and app downloads. Get the better data experience with network-enhanced quality. LTE gives you a faster internet experience with speeds of up to 69Mbps download and up to 25Mbps upload. Check whether you have coverage to ensure the best possible speeds.
Well, their website is useless.
@Cell_C can you explain the difference?
ProAsm
#3
LOL, I don't think they even know what LTE is, I have a Cell C tower about 400 meters up the road and can see the whole of it.
I borowed a B618 modem router with a Cell C sim in it and averaged around 20 to 35 Mbps all times of the day with the built in antennae.
I then tried to get a sim out of Cell C and even Afrihost, but no-one would let me have a sim as they all said I do not have coverage at my house.
I am now on Telkom LTE which the tower is 2+ km from here and aquired a poynting antenna and now I enjoy an average of 85 Mbps.
Cell C can go jump in the lake.
Cell_C
Cell C Representative
Company Rep
#4
Hi ProAsm
Please PM us your residential address so that we can check on the available level of coverage in your area.
^MP
ginggs
Super Grandwizard
Super Moderator
#6
rory
#7
I have spent quite a long time doing research on this and asking cell c, axxess and afrihost with very little clarity besides one is fixed and the other is not and I have no fixed LTE.
Then suddenly a friend kindly found this comment on mybroadband from member Sumen at this link.
https://mybroadband.co.za/forum/threads/lte-vs-fixed-lte.994630/#post-22587514
"With Fixed LTE - you only allowed to connect to towers that have been allocated for this use, you won't be able to roam on other networks, also majority time it's either 4G or no Internet.
With LTE you can connect to any tower with the ability to roam - you also can connect to 3G.etc"
Cell C rep is this correct ie the cell c tower I am connecting to is not a cell c tower and you are masking mtn or vodacom towers and making them look like cell c towers ie no roaming on my phone or router.
