Centurion d5 gate motor
herman1984
Help please my gate motor opens to pedestrian mode only with remote. When i open the box and oush the switch on the pc board the gate works normal any help please
Dear OP, welcome to MyBB
If you visit centsys.co.za you will see many useful pieces of info about the D5 and troubleshooting this exact issue.
Is it a d5 evo, ie does it have the clever controller? If so, delete your remote button and re-add it, selecting normal open not pedestrian open.
What transmitter and receiver are you using?
If the Nova receiver, read on
The controller is capable of learning up to 500 CENTURION NOVA rolling code
remote control buttons (KeeloqTM encryption). Each transmitter can have up to
four buttons.
Each transmitter learned into the system is assigned a unique transmitter ID.
 Press valid button
If the remote controls menu has been locked as discussed later, only by
pressing a button of a transmitter learned into the system, can the remote
controls menu be accessed.
 Add remote
Any button can be set to control the trigger, pedestrian, free-exit, Holiday
Lockout or courtesy light control (Aux) inputs. When adding transmitters, it is
recommended that a record be kept of the ID number allocated by the system
to each respective transmitter and the person to whom the transmitter is
given. This is necessary should selective deletion be required at a later stage.
 Delete remote
Transmitters can be deleted at any stage according to one of the following
methods:
 Delete remote by ID
Each transmitter can be deleted individually according to its unique ID. To
facilitate this, a record of the ID and the person to whom the ID has been
assigned must have been made at the time of learning the transmitter into
the system. The transmitter is not required for this operation.
If the backup module is used to restore the settings of a different D5-
Evo operator, then the gate limits setup procedure must be performed
again.
 Delete remote button
The operation of a button of a particular transmitter can be cleared For
example, it allows the Holiday Lockout function set on one remote button
of a transmitter to be cleared, without affecting the other operations that the
same transmitter performs. The transmitter is required for this operation
 Delete remote by button
Use this procedure to remove the transmitter from the system. All button
functionality will be removed. The transmitter is required for this operation.
 Delete not present
Allows for transmitters that have not been used within a selectable time
period to be removed from the system. The time period can be set from one
hour to seven days, in one hour increments.
 Delete all remotes
Clears the entire memory. All transmitters will be removed.
 Edit remote button
Change the function of one button to perform another function. For example,
button one’s function is to open the gate completely. To change this, use the
edit remote button, select Ped, and button one of the same remote will now
only open the gate to pedestrian.
 Autolearn
Allows a selectable time period to be set, during which any specific button,
when pressed, will be learned to a specific function. The function itself will also
be activated when the button is pressed. After the time period has expired
autolearn is disabled, and no further buttons will be learned. The time period
can be set from one hour to seven days in one hour increments.
 Tx menu locked
Allows the remote controls menu to be locked, preventing the unauthorized
addition of new transmitters to the system. Once enabled, the remote
controls menu can only be accessed by pressing a valid transmitter button.
If another receiver (like an ET) then...
There are 2 inputs on the D5 board
Trg
Ped
An input to the TRG terminal will make the gate open fully
An input to the PED terminal will make the gate open to the pedestrian gap
four buttons.
 Add remote
 Delete remote
methods:
again.
 Autolearn
 Tx menu locked
Trg
Ped
Hi still got the old one black button remote this stated after a powerfailure, gate will work fine for 2 days then its starts to just open to pedestrian mode and if i disconnect the battery and powersuplly for a while and reconnect it then the gate will work correct but about for o ly 2 days then it starts doing the pedestrian mode
I would suggest checking the battery. If powerfailure was long the battery could have dichargerd to low and could be at it end and take up the new charge again. On opening battery volts drop to low and gate stops short
