SianD
Are CFE lithium batteries any good? If not, what would you recommend please? For a 5kwa inverter. Thanks
Forgot to ask which inverter do you have?Are CFE lithium batteries any good? If not, what would you recommend please? For a 5kwa inverter. Thanks
Was quoted on a Sunsynk with a CFE battery. Know the Sunsynk is good but not sure about the battery.Forgot to ask which inverter do you have?
The reviews look fine overall, but others in the know may be able to confirmWas quoted on a Sunsynk with a CFE battery. Know the Sunsynk is good but not sure about the battery.
Read through this entire thread and make up your own mind:Are CFE lithium batteries any good? If not, what would you recommend please? For a 5kwa inverter. Thanks
