Hi guys..
I need some advice on choosing a laptop cooling solution. I generally use my laptop a lot on my bed (directly on the comforter) which caused a heat retention and cooling issue. Typical usage time is about 8+ hours (incl when left on for overnight downloads). I guess the usage plays a big part in deciding what solution to choose. If it makes any difference, I am currently using a HP Probook - however I would like the solution to be laptop agnostic.
I have looked at the following products which interested me the most:
I guess I just need some advice about laptop cooling in general and possibly a recommendation on the type of solution that I should be looking for. Also if anyone has any experience using any of the above, your thoughts and comments will be appreciated. I am more than happy to entertain other types of solutions.
