Cleaning Solar Panels
Adeptus Mechanicus
Here
Do you guys do it?
If so what do you use and have you found any benefit in doing so?
Came across an article that stated you can lose around 10% a year with grubby panels.
No need, unless they are really dirty, as in you can see a layer of dust on them, otherwise let rain take care of it.
If you really have to, soapy water, preferably nothing too harsh, I use my car shampoo.
I was thinking a bucket of water with diluted vinegar and a soft sponge
Followed up with maybe some window cleaner sprayed onto a microfiber cloth (rather than soaking the panel in the stuff)
Nah, unless you are exceptionally bored and would like to extend the chore, otherwise, a good pressure of water to remove most of the dust, then window cleaner and apply with that squeegee thing they use to clean your windscreen, preferably on a longer handle. Then hose again and wipe of excess water.
Don't be shy, they are designed to withstand torrents of rain so they won't mind what you throw at them.
Do you guys do it?
I didn't realise the search function was broken
...and I didn't realise a thread dedicated to getting an opinion on single product constituted a complete discussion on the merits/methods of cleaning solar panels, such that other threads are now superfluous.
But hey, that's just me.
I just dry mop them to get rid of dust settled on it.
Too scared to use water on the roof as I am scared I will slip and fall.
Unfortunately I cannot find any anchor points on the roof to hook myself up with a safety harness.
Do it sitting down, you will look like a Boss, no one will ever know.
Hose it down like a real man, otherwise use your garden hose.
Only time I used window washer, was for the hadeda's bombs which I swear was a quarter of the panel big.
Do you guys do it?
Ask @Neuk_ - he’ll even come round to do it for you.
Do you guys do it?
I’ve done it once in the 3 years I’ve had mine. I don’t bother it’s not worth it.
The worst, and it takes some heavy rain to wash that crap away.
  • Like
Reactions: rh1
Make sure to use Woolies vinegar and a blue micro fiber cloth. Only rub the panel in anti clockwise movements.
Disclaimer: I might be taking the piss.
