K kitkat+ Senior Member Joined Apr 2, 2017 Messages 679 Reaction score 70 Jun 27, 2017 #1 Hi Guys Is there way for me to replace a 3 pin plug with a 2 pin ? I want to use my laptop on a long bus trip. I have one of these in the image but the adapters in the bus are more flushed in. Thanks Kitty Last edited: Jun 27, 2017
G gfmalan Expert Member Joined Nov 11, 2013 Messages 2,676 Reaction score 249 Location /\/¯¯¯¯¯¯\/\ Jun 27, 2017 #2 Yes, cut it, and replace
R RoganDawes Expert Member Joined Apr 18, 2007 Messages 1,464 Reaction score 161 Location Randburg Jun 28, 2017 #3 You can change it, although you will be giving up the earth connection in the process. This is unlikely to be a problem in practice, as the power supply brick will be double insulated anyway.
V Venomous Honorary Master Joined Oct 6, 2010 Messages 54,775 Reaction score 2,281 Location ♫SyNoNyM♫ Jun 28, 2017 #4 Or keep your cable and look for the one you want to use on the bus?
