TheGene
Hi guys....
I need some advice please...
I have a D-Link that is used as the main access point for my ADSL. It is a DSL-2750U.
I would like to use my Billion 400g to connect wireless to this and then connect wired to the Billion with my various pc's. Here is a graphic:
ADSL -----> DSL-2750U ------> Windows pc, Laptop, Windows pc, Windows pc.
Billion 400G -----> Windows pc connected wired
Linux pc connected wired
Laptop connected wired
I need to try and do this as it is simply not feasible to run a cable over to where my pc's are.... at the moment what is happening is that I transfer quite a bit of data between the second set of computers and that slows the wireless network down terribly, as the D-Link has to do all the work. If I can get the Billion to connect to the D-Link for internet access I can then use the wired setup on it for my transfers. LOL I hope this makes sense, if you need any more information pls dont hesitate to ask....
I need to know whether it is possible to use the Billion as a connection from my pc room to the d-link basically, so that if I need internet access, I do not have to use a wireless card(s) at all.
Thanks in advance for ANY input....
