D-Link | How can we help?
D-Link
D-Link Africa Representative
Company Rep
Eco Fusion 6, Witch-Hazel Avenue, Centurion, 0046
Hi there,
We at D-Link would like to have a bigger presence here on MyBB and assist you in any way possible with our Products and Services.
Please feel free to PM, post, tag, email or call us on 08600 DLINK (35465).
Support Hours : 08:00 to 21:00, Monday to Sunday
You can also find us on Twitter @DlinkSA and on Facebook.com/DLinkSA
Kind Regards,
D-Link | Building Networks for People
Very cool of you guys.
Welcome. :)
P.S I'm sending all config requests your way now. :p
YES BOYS
awesome to see more companies getting their presence on these forums
Great news, I love your ADSL Routers! Using the D-Link 2750u - quick and great config setup menu.
This is good news. Perhaps you can assist. Currently using a Dlink 2750U router with the standard Webafrica DNS Settings on. Every few months I am having major problems with the router. Only some pages are opening up. No Https sites are working etc.
Now I have contacted Webafrica each time and according to them, the problem is with the router. This however I cannot understand cause up till that stage the router worked perfectly.
This has now happened 4 times. Somewhere between the router, Webafrica and Telkom's exchange things are not working and I get this problem. Each time the issue disappears within 3-4 days.
Have you received similar complaints?
Looks like a DNS issue
I have a 150mbps D-Link wireless bridge connected via LAN cables to my Yamaha Receiver and Gaming Machine.
The Bridge is connected to my D-Link 2750U wirelessy.
On the other end, I have a server that is connected wirelessy via a D-Link DWA 140. Accessing this server and browsing through its folders from the Gaming Machine takes FOREV and all my movies stutter for at most 15 seconds.
What is the latest firmware available for this router and for the bridge?
Also, when the power trips, I have to access the config of the bridge each and everytime to specify which hotspot I must connect to, almost as if the bridge had a complete deep reset. Is there an update available where I don't need to do this every single time?
My D-Link 2750 keeps disconnecting the devices connected via wifi, why?
Could you please check the value of your Group Rekey Interval. It should be on 3600.
This sounds to be a DNS issue with your ISP. However you are welcome to drop us an email at [email protected] to take your enquiry further.
What is the distance between your wireless devices? If you are using an older 150mbps device at a far distance it will not run at full speed and this could be the cause of your media having to buffer/stutter.
For the latest firmware on all our devices please go to ftp.d-link.co.za
What firmware are you running? I had the same issue with that same router 2 years ago. Changing some lame bandwidth setting fixed it for me, but after updating the firmware, I changed it back and it worked fine.
5 meters from router in line of sight and 10 Meters from server, line of sight as well.
