SteveO
Hi Guys
Looking to see if anyone has had a similar problem or has any advise.
my pc was working perfectly on sunday eve and i had shut it down etc that night, turned off the power at the mains etc.
On monday after work i got home and tried turning the thing on but it was dead, only the green standby light on the mobo was lit.
So i proceeded to check connections etc, check the power switch took out the PSU and tested it, was A ok.
So thought i was prob the mobo acting up.
On the advice of the guys i bought the system from (they in CT and I am in JHB now) i disconnected all the non essentials, re-installed the RAM and then tried booting again. After playing with the switch a few times it booted, however there was a constant, long beep.So i figured it was moaning bout things not being connected and re connected all the HDD's, DVD drive etc
The system then booted without a hitch, but now i have no output to my LCD. The LCD is working as i am running my laptop on it in the mean time but i cant pick up a signal from the desktop PC. Video Cards fan is up and running and all the power connectors it needs are plugged in etc.
besides the obvious video card being stuffed are there any other suggestions?Could it still be the mobo as i dont get the usual 'beep" on a good boot.
My setup is as follows:
Intel Core2 Duo 8400
Asus P5N-D mobo
2 Gb RAM Apogee
Nvidia 8800GT
2x 320Gb SATA HDD's (stripping)
Coolermaster 650w PSU
any help would be appreciated
thanks guys
Asus P5N-D mobo
2 Gb RAM Apogee
Nvidia 8800GT
thanks guys
