DialCheap super low call rates
cavedog
PTA
So I recently discovered www.dialcheap.com
Now I was shocked when I saw that their call rates are so low. 14c per minute to any network in SA excluding premium numbers.
So I started to give them a try.
First of all loading credit. Not flexible amounts so it starts from $10 upwards.
Now here is where things get really interesting. The methods that you can make a call is via call back which means you get charged for the call back and for the call you make, sip so you dial via sip details, local number you dial then you punch in your number you wish to dial and via software on the pc.
So I setup sip in my Telkom LTE router and it works very well. SIP server is located in The Netherlands so latency is higher than a local server but the quality was still very good.
Once you registered you can setup the CLI to be your cellphone number or your landline number by verifying that you own that number via sms or callback.
So when you make calls it will show your number as if you were dialing from it.
Calls are really really cheap at only R0.14 per minute any time any network in south africa. Once you registered your account as from South Africa the system automatically picks up when you dial south african numbers and you do not need to dial in international format unless you dial an international destination or registered your account in a different country.
There are some cons though but still very reasonable.
*International sip server
*Per minute billing throughout the call
*Service fees when topping up. Bitcoin is the lowest fee @ only $0.05 service fee
*Limited payment options but they do have paypal,bitcoint and visa/mastercard but as I mention service fees are high with those payment methods best is bitcoin.
*No flexible topup amounts. Fixed denomination topups.
*No incoming calls, local did or national did for incoming calls.
I did some more researching and looks like there are a bunch of these VOIP resellers out there reselling from one large company but their rates differ quite a bit. The lowest for South Africa rates is dialcheap.
$10 is roughly R140 depending on the exchange rate which equates to 1000 minutes to any network any time. You just can't beat that rate. Wow
Works flawlessly with the Huawei B315 router on Telkom LTE.
Brilliant find! How is the latency on calls though? What with the SIP server being hosted internationally?
The sip server is sip.dialcheap.com so you can ping it and see what the latency is like for me on Telkom LTE it's about 200ms which is high for VOIP but low in terms of the distance. I have not yet picked up call issues and even if there was the call rates are so cheap I won't expect an elite service.
Nice getting between 190 and 210 max.
These rates are MUCH cheaper than local sip providers, guessing the main issue with this will be support though.
Below you can see your CLI settings. Verify your numbers and a one click solution to change your CLI settings for calls. Very very coolo feature.
You can also enable or disable sip for your account.
They have a website, mobile site and then apps for most phones and for your desktop.
When I loaded with bitcoin it showed successful but I did not get credit loaded. So I emailed them straight away.
After about 10min the credit got loaded looks like they just waited for a couple of confirmations on the bitcoin network before the credit was loaded. Support replied in 1hour 30min saying they need to wait for confirmations first then the credit gets loaded.
So yeah support could be an issue but I've seen worst support from local VOIP providers honestly.
This seems to be another variant from the Betamax family. If you need to make regular international calls, some of the other services may offer free landline calls for 3 or 4 month periods. The rates change regularly so you may need to switch services after several months.
http://betamax.backsla.sh/betamax
Well as it stands now these prices are insane. Spoke for 23min on the mobilevoip app and was charged only R2.98.
Unbelievable low rate wow.
Not sure what codec is being used but the voip app and telkom sim roaming on mtn gives excellent quality and crystal clear voice. I'm very impressed so much so that the people I was calling did not even know I was dialing with voip.
Probably G711U/A, quality is very good with this codec on the expense of data usage. Install Zoiper on PC or the phone, it will display active codec. It can be used simultaneously with router.
BTW, I use SIP server in Europe as well. On the fast LTE connection SIP server can be overseas, I see no difference. It might matter when using proxy/STUN server though.
