Try changing the APN from "internet" to "TelkomInternet". Telkom has quite a lot of restrictions on the normal "internet" APN.
You need to change it to unrestricted
And if you want it tk be open completely then use the DMZ option in the router and point it to your Xbox IP. Nat should be open now.
Never tried the APN change thing. Will give it a shot.
I was able to get open APN using the DMZ option on my router but Warframe still giving a warning about open ports.
