ichigo
Uploading the pictures of the dish and cables now
Not ignoring you I will have check when im home imageshack blocked at work.
Nice ManicureThanks![]()
Nice Manicure
Jokes aside
Thats a single LNB! thats why it doesn’t work that splitter the installed aint doing jack and from the looks of its wear and tear looks to me as if its been their a while already.
How much did they charge you for the initial installation - do you have an invoice and what does it say on it
Was R400 plus R300 for last call out so R700 we wasted so farfor them to put it in and fix it and we did it in September, but cant remember when the first cable was put in
The invoice said Call Out Fee + Cabling, Setup & Test - 17 Sep 2012
New one said Call Out Fee - 1 Feb 2013
when you called them out what did you ask them to do?
I have to be honest If you asked to them get you ready for xtraview or HD PVR they did no do that, it looks as if they just split you original lnb in 2 which wont work correctly for either -so wither they didnt understand what you wanted, they understood and then they really useless installers or they ripped you off![]()
Asked them to put in a LNB in the other room where we moved our lounge/tv to and to keep the other one for extraview/pvr when we decide to use it properly and incase we change our mind about our new lounge spot.
They are multichoice accredited installers reason why I chose them![]()
eish phone them ask for the manager, explain what you ask for and what you ended up with, and if you get no resolution then complain to multichoice or go the hellopeter route. not sure what else you can do ?
Thanks will try what you suggested and hopefully when they come tommorow they will correct their mistakes
and don’t pay anymore, call out fees etc! they made the mess up you shouldn’t pay more for that
Yes my mom wont make the same mistake again and how much should a dual lnb cost since they charging R700 for the item, if I wanted it.
You can get for R200, don't pay more than R350/R400, I would buy it myself and tell them to instal it
Not sure what shops you have in PMB but you can get here from SpaceTV, or order online from HD Cabling http://www.hdcabling.co.za/for-hdpv...-band-dual-twin-lnb-2-legacy-ports-p-276.html
I lol'd at the HD Ready featureThe dual lnb I bought today for R280 from the Radio World
I lol'd at the HD Ready feature![]()
They finally came and tried to say they were going to charge us, then I complained it got worse cause of their company and showed them
Waiting to see what they do next and not like I can pay them since I only use cards not cash lol![]()
good luck and dont take there crap![]()
