DSTV PVR - Explora issue
BigBear
PRETORIA
2014/09/21 DSTv explora Recording issue: http://youtu.be/wmyf5KyvtOM
Running Latest Firmware and have tried:
Delete Episode
Delete Series
Cancel All Recordings
Cleared Schedule
Reboot numerous times..
any ideas ?
They just keep coming back and cause conflicts..
Try press "i" while highlighting the episode, it should give you more info on the problem.
Check the last post, maybe it will help, remember to write down your current XtraView settings :) http://mybroadband.co.za/vb/showthread.php/610012-How-do-I-format-the-Explora-s-HDD
BEWARE. You will lose decoder settings, XtraView setup, UHF output, scheduled recordings etc etc.
MENU (DStv button) -> Use left/right arrows to select SETTINGS -> Down arrow to select SYSTEM SETTINGS -> Forward arrow, then down arrow to select RESET DECODER SETTINGS -> Press OK -> Down arrow to select RESET TO FACTORY DEFAULTS AND FORMAT HARD DRIVE -> Select FORMAT THE DECODER -> Press OK
http://mybroadband.co.za/vb/showthr...lora-s-HDD?p=12452510&viewfull=1#post12452510
... Rather not don't want to lose other recordings..
