Chris_H
E620 LED Info
OK, so I've got an old-ish E620... I've got some problems with my connection that seems to freeze at times and quite often. I know what the card is doing from the LED states. I've figured the following out:
2x green flashes - looking for signal
steady green flash - found GPRS
solid green - connected to GRPS
steady blue flash - found 3G/HSDPA
solid bright blue - connected to 3G/HSDPA
Now the data transfer will stop while the LED is still light blue. I can refresh the pages all I want but nothing. Then the LED truns darker blue (stil solid) and then about 5 seconds later it turns light blue again and then the data transfer is fine again. I am using a D-Link DIR-451 wireless router with the card and have flashed the router with the latest firmware with support from D-Link SA.
Anyone know what happens when the LED goes dark blue? My signal always seems constant around 50% or more.
