I work from home and Escom's load shedding was REALLY getting me down. Problem is, generators cost a lot of money (or so I thought). Just out of curiosity I went to a shop yesterday to see what they had. I ended up buying a little 750 Watt generator. This thing is very small - about 30cm cubed. It cost me a whopping R700. (I bought in from Wikkies Pompe in Pretoria).
I took it home, fired it up and plugged in my desktop PC (Pentium D 805, 1.5 TB HDDs, Radeon X1950 Pro, 19 inch LCD). It worked like a charm. I then tried to see what else I could drive off it. I plugged in my dual 1 meter tube fluerescent desktop lights. No problem. Next came my ADSL router and cell phone charger. All worked fine. I let it run like that for a couple of hours just to make sure that all was well. I even fired up Stalker to see if 100% CPU load would overload the generator. Not so. My problems are solved.
All I need to do next time Escom stuffs up is to roll out the lead, fire up the little gen and plug in my power strip. My PC has got a UPS (about 5 minutes) so I don't even have to reboot.
Seems to be. I ran the PC off the generator for about 2 hours and the UPS didn't complain. It is a UPS Direct 1000VA.Is the UPS genny compatible.
It is called a Red Rhino GC950DC although I think it is basically a no-name brand Chinese unit because the name does not appear on the manual at all. Wikkie's Pompe (Google it) still has a lot of them left but the sales guy told me that they are moving very fast.Great news - post the specs of the genny and UPS up so others can benefit from it.
Oh, does the genny start easily? I don't want a thing which you'll have to pull a million times before it starts...
Dunno. My logic says so. A UPS is supposed to filter spikes and dips out of the supply current so I think it is a good idea to run a UPS.I heard it is not too good to run a PC direct from a genny, always run it through a UPS to clean the power first.
True?
Is the UPS genny compatible?
Sounds good - haven't had any loadshedding at home ... yet ... but will look at that if it comes down to that.
Surge protector should also filter spikes?
Nope, it'll only filter serious surges, not normal fluctuations.cyberarmy said:Surge protector should also filter spikes?
Why don't they fix their electricity network instead of dumping more and more laws on us. Idiots!btw there is new legislation coming out about genny usage. Haven't heard anything via official channels, but its coming...soon.
Sure, true. Just put it outside.Dude be very careful when handling generators, the fumes generated by generators can KILL people, I heard on Talk FM that people should be careful using them.
