It is called a Red Rhino GC950DC although I think it is basically a no-name brand Chinese unit because the name does not appear on the manual at all. Wikkie's Pompe (Google it) still has a lot of them left but the sales guy told me that they are moving very fast.
Here's the basic specs according to the manual:
Continuous AC output: 650 Watt
Max AC output: 720 Watt
Type: 2-stroke, reed valve, forced air-cooled, single cylinder
Fuel: Unleaded gasoline
Lubrication: 50:1 pre-mixed fuel
Fuel tank: 4.2 liters
Displacement: 63cc
Continuous run time: 5.8 hours
Weight: 18.5 kilos
It took about ten pulls on the very first time I started it. This is probably because the fuel supply was not primed yet. After that it starts on the first pull every time. BTW you don't need to use the choke as specified by the manual. I think our climate is too warm for that and it only causes the motor to flood. Simply open the fuel tap, switch it on and pull once. There you go.
The UPS is likewise a no-name unit because I can't find anything about it on the web. It simply reads "UPS Direct 1000VA". It has given me about two years of trouble-free service thus far.
You can have a normal conversation next to it. It is more or less like a motorcycle at idle. I'm fortunate to have a reasonably large yard so I just put it outside where it bothers nobody.
I take it you're not best of buds with the neighbour.
My mom is planning on getting a generator but the company (Volt Ampere electrical and mechanical engineering) quoted her 35k for a 8.5kVA diesel generator, is that seriously what it costs?
I looked @ a Honda 5kVA unit which costs around R6k but I assume running two of those in parallel would be a very bad idea...
Hi guys, just bought a Ellies Silent Diesel Motor Generator - 5 or 5.5 kVA similar to the one here http://www.ellies.co.za/v2/index.php?id=724
Now how do i go about connecting this?
I've heard you can turn off all switches on your mains and run a plug from the generator to one of the plugs in the house and this will provide power to all other plugs in the house creating a circuit...however this does not sound safe, nor a very permanant solution..
How are you guys connecting these generators? Should i call an electrician rather?
Another thing is that i want the generator to switch on automatically when the power goes. How would i go about doing this?
The guy i bought it from said something about a DV board or ATS board or something which i would have to purchase in order to achieve this with this generator (follow link above). How exactly does it work?
Thanks for any help/tips...
Dude, I am no electrician, but that sounds seriously dangerous.
If you do it the correct way there is no problem. Very much possible.
http://www.gen-tek.co.za/specials.html
I am planning on getting this .
Was the price that you paid for the ellies model roughly the same or not ?
If you don't mind me asking
