First Karmic issue - manual fsck
sn3rd
My girlfriend freaked out today. Her netbook hung, and wouldn't reboot, complaining the filesystem could not be mounted. I ran a fsck and all was fine.
I chalked it up to her screwing around, but when I booted my netbook, the same issue occurred. Same fix.
So for anyone this happens to, make sure you know what your root filesystem is
Code:
df -B G
or
Code:
cat /etc/fstab
then assuming your root partition is /dev/sda1 you should run
Code:
fsck /dev/sda1
from the root terminal it crashes to
This will do a fsck on all drives at bootup...
Code:
sudo touch /forcefsck
I wonder whether the problem would be with / or /boot, if you have them on different partitions?
Probably a file system issue many Karmic users are experiencing.
