turbochargd
Hi guys, im looking to keep important files backed up somewhere other than a cloud drive or external hdd. Cant afford SSD so im considering Flashdrives or SD Cards. What would you recommend? Any specific brands to consider?
How much data are you talking about?
20gb to 50gb (pics,clips,documents) hence why im considering either flashdrive or SD card...
What's wrong with just having an external hard drive used for general purpose backups? Quality 64GB memory cards and flash drives aren't cheap.
Quality in terms of memory cards pertains as much to speed as it does to anything else. Since you can pick up a 32gb class 10 SD card for under R200 it's not really a bad option as long as you buy two.
I had a 128gb Verbatim usb stick I bought in September die on me the other day and it was a bit of a schlep to back all that stuff up onto a second device but it had to be done. One copy on one device isn't a backup, it's a disaster waiting to happen.
I've got a stack of 20+ hard drives that I have to remember to spin up and check on a regular basis - if I could move all of that onto something that didn't rely on moving parts I'd be a much happier camper.
Definitely, once they're on par with HDDs in terms of price and capacity.
Except he specified no SSDs .Which will never happen...
For the OP though it's perfect.
Pics and clips, backup to Google Photos for free. Plus point is, that it's accessible from a lot of different devices.
What's the size of the docs, I guess it should be a small percentage of all that.
Uploading to Google photos isn't without potential pitfalls, especially if he shoots raw files and/or has a slow or capped internet. He might also not be keen on google's licensing terms.
