isie
- Jan 16, 2010
oops ah sorryI said money is an issue. 1 x mppt and 2 or 3 panels is cheaper than replacing 5kW with 8kW.
Really? I strongly disagree, I have 24 tubes, small circulation pump into a 200l geyser, this without the geyserwise.Indeed. Those tube things are useless. Replace with 4 pv panels and controller.
Sure, I guess size does matter. Is yours facing NE too? But you said it yourself, even this monstrosity doesn't work all year round.Really? I strongly disagree, I have 24 tubes, small circulation pump into a 200l geyser, this without the geyserwise.
I heat it with electricity about 3/4 times a year, in fact the geyer is off at DB board. Space it takes up is about 1 panel size.
faces NNW, can fit 1 panel into that space.Sure, I guess size does matter. Is yours facing NE too? But you said it yourself, even this monstrosity doesn't work all year round.
How many solar panels could you fit in the space that takes up?
How much did it cost?faces NNW, can fit 1 panel into that space.
8what the inverter size?
8kW, 5kW is not even an option unless you a single personProb 5kW.
Then why you worried over the geyser?
He's worried about using battery. Looks like there's only 2kWp of solar.Then why you worried over the geyser?
Yeah who ever did his system wowserHe's worried about using battery. Looks like there's only 2kWp of solar.
east/west array so bad in winter. I would add 2 biggest panels one can get on the small patch of north facing roof.Yeah who ever did his system wowser
First problem is splitting it like that. All panels face North East as much as possible. Second string can handle West later on. But only 2kw of solar with 8kw inverter?? What's the battery?east/west array so bad in winter. I would add 2 biggest panels one can get on the small patch of north facing roof.
2kW now because its winter, I would assume it double in summer.First problem is splitting it like that. All panels face North East as much as possible. Second string can handle West later on. But only 2kw of solar with 8kw inverter?? What's the battery?
Then he'll have to just keep using grid for geyser.2kW now because its winter, I would assume it double in summer.
Its easy to put a seperate victron mppt for 2 panels on north roof and connect straight to battery.
No idea on battery size, prob 10kWh.
He doesnt have money for second string.
At least upgrade element for R300 so it doesn't take 6 hours to heat up. Then water will be hot from the 12:30-14:00 timer.Then he'll have to just keep using grid for geyser.
well I cannot change the house direction for winter and looking at my roof I dont have much of a choice, once August comes I am back with enough generationeast/west array so bad in winter. I would add 2 biggest panels one can get on the small patch of north facing roof.
yes it is what it is until I get more panelsThen he'll have to just keep using grid for geyser.
2kw will heat in 5 hours and a 4 will heat in half that and use the same power less time is how I see itAt least upgrade element for R300 so it doesn't take 6 hours to heat up. Then water will be hot from the 12:30-14:00 timer.
Yes. So you dont have to wait half the day to have a shower, only 2 hours.2kw will heat in 5 hours and a 4 will heat in half that and use the same power less time is how I see it
