I only shower at nights and cater for the time to heat the waterYes. So you dont have to wait half the day to have a shower, only 2 hours.
huh - then why the 2 kw?
2kw will heat in 5 hours and a 4 will heat in half that and use the same power less time is how I see it
Why you only running timer for 2 hours?I only shower at nights and cater for the time to heat the water
Why is the water ice cold the next day?I only shower at nights and cater for the time to heat the water
Mans getting bombarded with some very personal questionsMans getting bombarded with questions![]()
R7500 installed in sept 2012, With eskum rebate programHow much did it cost?
These days it’s not worth going tubes, cheaper to integrate geyser into inverter setup.R7500 installed in sept 2012, With eskum rebate program
Yeah not at the prices they are asking, panels is the way to go these daysThese days it’s not worth going tubes, cheaper to integrate geyser into inverter setup.
Did you miss the google maps pic of the house where you can see the solar geyser?@duderoo
Just looked through the thread to get info you have an 8kw inverter, 10 panels (5 East, 5 West) only enough roof space North facing for 2 panels, and 5 more panels in the East end West side And a solar Geyser
Information we missing inverter model, battery capacity and battery model, solar Geyser type( direct, indirect, flat, ev tubes etc), is the Geyser on the east of West side, Panels wattage and set up(if they on seperate strings or on the same mppt etc)
Just FYI that I had to have an early shower and water was cold ( lizardPerson had a shower last night) 30°c
Geyser went on at 4am and off at 0422 45°c in 22 minutes it went up 15 degree and used about 1.3kwh. on you side that would probably take a couple of hours![]()
Am2’, this limits you to only am2 or other nmc (not aware of any other nmc) for expanding.
PanelsAm2’, this limits you to only am2 or other nmc (not aware of any other nmc) for expanding.
Is it not a package deal? They don't mention kWp.Panels
Forget the other stuff.
Nope but it was early and I could not make out the Geyser collector type and based on the north arrow its east side but Id rather make sureDid you miss the google maps pic of the house where you can see the solar geyser?
It is not nice cold but colder due to winterWhy is the water ice cold the next day?
I got about R5k back whenever for a solar installR7500 installed in sept 2012, With eskum rebate program
Deye 8kW and 10 kwh battery but only goes to 30% and so 7.6kwh when fully charged but a struggle the past few days with cloudy weather and all.@duderoo
So you have plenty of room on mppts. You can just add a panel or 2 on each side?Deye 8kW and 10 kwh battery but only goes to 30% and so 7.6kwh when fully charged but a struggle the past few days with cloudy weather and all.
Solar is direct and east side but as the sun angle is screwed in winter and the water so cold, it barely does much tbh.
Panels are 550W, but all about the angle's of the sun and that so a challenge as mentioned. 5 on one mppt and 5 on the other.
Whatever the water temp is maybe 25-30 degrees I still shower, wash the basics and out![]()
