Hard Drive Problem
medicnick83
Paramedic
Hi peepz!
I have this 320GB HDD that has semi died I think.
It was in an external casing and starting giving me this blue screen error: bugcode_usb_driver
Anyways, I took it outta the casing and now it gives page fault page blah blah blah blue screen error.
I need to get the data off this drive, but if I put it and turn the PC on, the PC gets to a point and Blue Screens.
Any ideas?
The_Unbeliever
use knoppix?
can you run chkdsk on the drive before copying off data? (probably will lose some data on bad sectors tho)
wait for other ideas before running off. Take it easy, don't rush things.
mercurial
MyBB Legend
Take the HD to another pc and connect it up as another drive. Then transfer the data.
Devill
Damned
If there is nothing "private" on the HD then take it to a data recovery place..... will cost a few Rands but hay next time dont load porn on the HD :D
mercurial
MyBB Legend
I've done this... I have 2 PC's
In both PC's I get the BSOD either IN the external casing or out of it.
I don't understand :confused: Are you getting the blue screen even though you're not using the HD as the boot up drive?
The_Unbeliever
Have to agree - it's weird.
All I can think of is that a defect developed on the removable drive's MBR or in some other critical area, when Windows try to access it, it doesn't know how to handle the error, and bluescreens.
Can also be a rootkit/virus/trojan tho...
Devill
Damned
Take it to the pros, pay a couple of bucks and all your worries are solved :)
mercurial
MyBB Legend
If you don't connect the device, the other pc works fine? Have you tried "Last known good configuration"?
medicnick83
Paramedic
If I disconnect the drive, yes, the PC works fine, boots up.
I haven't tried "last known good configuration" :(
I'll try this, but something tells me, this won't work either :(
