2.7.2 Advanced Wireless Settings
Normally, there is no need to make any changes here. Unless you know that your
network requires special settings, you can proceed to 2.7.3 Wireless Security.
Fragment Threshold — Set the fragment threshold of the wireless radio.
NOTE: If you aren’t sure what this should be set to, leave it as the default value of 2346.
RTS Threshold — Set the RTS (return to sender) threshold of the wireless radio.
NOTE: If unsure what this should be set to, leave it as the default value: 2347.
Beacon Interval — Set the beacon interval of the wireless radio. NOTE: If you
aren’t sure what this should be set to, leave it as the default value of 100.
DTIM Period — Set the DTIM (delivery traffic indication message) period of the
wireless radio. NOTE: If you aren’t sure what this should be set to, leave it as the
default value of 3.
Data Rate — Set the wireless data transfer rate to a specific value. Since most
wireless devices will negotiate with each other and pick a proper data transfer
rate automatically, it’s not necessary to change this value unless you know what
will happen after modification.
N Data Rate — Same as above, but only for 802.11n clients.
Channel Width — Set the channel width of the wireless radio. NOTE: If you aren’t
sure what this should be set to, leave it as the default setting (“Auto 20/40 MHz”).
Preamble Type — Set the preamble type. NOTE: If you aren’t sure what this should
be set to, leave it as the default setting (“Short Preamble”).
Broadcast ESSID — Decide if the wireless router will broadcast its own ESSID. You
can hide the ESSID of your wireless router (select “Disable”) so only people who
know the ESSID of your wireless router can connect to it.
CTS Protect — Enabling this function reduces the chance of radio signal collisions
