Abadon
Hi All,
I hope i am posting this in the right place. I am trying to setup a webserver and have spent days trying to set ports and my router so that my system can be accessed by others, with no luck.
Here is what I am trying to do and what I have done so far.
I installed Apache,MYSQL,PHP, for use with a virtual world based on the OpenSim project. Everything is working as it should on localhost. However I can not seem to get the config right for connections from others.
I am supposed to have a static IP. Here i set a static IP in windows with pref DNS as the router. I got a DNSDynamic account, running ipconfig shows DHCP = No and IP as the one I had set.
Somehow i think the issue that I can not connect maybe to do with the router, I have read and re-read the manual and perhaps it could have to do with the NAT setting. I have also opened the ports in the win firewall
that are called for.
Am I on the right track here or totally off base, I would really appreciated any advice or pointers on where i could look.
OS = Win 7 64
Router = Planet WNRT - 625G
Abadon
OS = Win 7 64
Abadon
