[Help]Vodacom Power Tab 10 won't boot
sam7606
Yesterday i decided to do a firmware upgrade on my Vodacom Power Tab 10 as there was a notification about the upgrade on my device. So i hooked up to a wifi(upgrade wouldn't download over 3G) and started the download process. Left the tablet to do its thing, took a shower and when i came back the tablet was booting up(showed a spinning circle on the screen) and so i left it again. 30 minutes later it was still trying to boot. Ok so i thought maybe i should restart it and so i did, but still wont get past the spinning circle(shows Android logo, Vodacom icon splash then the spinning circle, wont go any further).
Now i started toubleshooting and this where I'm at:
*can boot into Fastboot and Recovery, but ADB doesnt work(doesnt see device probably cause USB Debugging is off), but can receive commands through Fastboot.
*Wipe Cache partition and Wipe data/Factory reset(through recovery mode) don't solve the problem.
*No Custom Recovery.
*No Stock Rom/firmware
Any help would be greatly appreciated.
