So basicaly i have started a thread around this before while i was on windows xp and couldnt find a solution.
I have no upgraded to windows 7 and I am still having problems.
I have a telkom account that is set as the default connection in the router.
I also have a seperate afrihost account that i use for gaming for the peering problems with mweb /telkom
When i create a seperate dial up connection on my pc to connect to afrihost, all seems fine untill i start browsing or try to connect to steam.
If i ping saix.co.za -t i can monitor what is happening. So my ping is 9 to saix on the telkom account, then as soon as i enable the webafrica account it goes to 53.
Now the problem comes in that as soon as i open up a new tab in IE, or try to connect to steam etc, the host becomes unreachable for about 5 pings, then it redials and the proccess starts over again. So i seem to be losing connection. It is most frustrating as im permanently capped on the telkom account so i cannot really game etc.
Help with this would really be awesome, i mean i just spent R500 on black ops and now its pointless
THanks for your time
