Help with Cisco SRP527W-U
Hotdog777
Hi There,
Im wondering if anyone will be in a position to help me out here.
I have recently acquired a Cisco SRP527w-u adsl router, but for the life of me cannot get this router to connect.
i have a telkom dsl line and Plugg access account.
Im using the same settingd from my billion router, but maybe missing something.
thanks in advance
Hi there,
Is this what you looking for.
Thanks for your assistance in advance
Encapsulation: PPPoE
Multiplexing: VC
Qos Type:
VPI/VCI Auto Detect: Disable
8/35
Virtual Circuit: VPI (Range 0~255)
VCI (Range 32~65535)
PPPoE Settings
User Name:
Password:
Service Name: Plugg
Connect on Demand: Max Idle Time Min (Range 1~9999)
Keep Alive
Enable MTU/MRU greater than 1492:
LCP Echo-Request Interval: Sec. (0 means no LCP Echo-Request)
MAC Address Clone
MAC Clone: Disabled
MAC Address: : : : : :
802.1Q VLAN Encapsulation
VLAN Encapsulation: Disable
VLAN ID: (Range:0~4079)
MTU
MTU:
MTU Size: 1492
Change your multiplexing to LLC
Yea that looks like the only problem to me. Are you sure you're putting in exactly the same password as before? (They're case sensitive)
